This is mesmerising
Two questions;
1. How much do you think the machine costs?
2. How long would it have taken to write and debug the CNC program?
yep its as if the phrase 'poetry in motion' was penned for the sight!The tool changes are amazing.
Howld on man there's human beens on this forum.Hard to say on cost of the machine but if, as the website says, it is made in Germany then I think it will cost a bit more than a HAAS but .....
Regarding the programme, it will have been done with CAM and likely only taken ten minutes or so to get the toolpaths. Debugging usually isn't needed as you simulate first and should see if there are any collisions or wrong moves in the simulation.
Howld on man there's human beens on this forum.![]()
It is like everything else, steep learning curve then fairly plain sailing after that.Easy as that. Once you know how to do it!
First step is usually to draw the part whether that is with 3D or just 2D depends on your CAD programme (Computer Aided Design) Next you open it in your CAM programme (Computer Aided Manufacturing) and then go through the steps of choosing the toolpaths, tools you want, feeds, speeds, depths of cuts etc etc then you do a simulation and check everything is OK and no collisions then finally you tell it to produce the code which you then send to the CNC.
I use BobCAD for my CAM programme and for the lathe it is especially easy as I have a template made up, I import the drawings, click the toolpaths and press Compute, may have to change a few things such as thread pitch but normally I can draw a part, put it to CAM, and have the code sent to the machine in under 5 mins.
