miggymarky
As i am thinking of renting a unit pretty soon,its obvious im going to need some sort of extraction,and was just wondering if anyone had made there own and how,as im on a tight budget.
The tubing used on tumble driers is pretty good and cheap if you need to run the ducting a long distance.
as mk says long runs need a smooth bore inside otherwise it bounces around in consetina pipe and reduces the flow volumeif its possible to do any long runs in solid pipe and then use flexi that will give you a better suck rate
