I've got this 5.5m x 4m garage, that I'd like to extend to the side by about 1m.
I'm thinking of removing the side wall almost completely, but leaving one panel on each "end". The roof is made from corrugated steel sheets, and it's held up with a 3mm 40mm angle steel, resting on the concrete sections (well, bolted into them, actually).
I was hoping to use some RHS to support the roof along the way of the opening (about 4.5m of it), possibly with a RHS pillar in the middle as well to keep it stable.
The walls to the side will be made with weatherproof plywood, and then clad in some wood, or rendered and then painted.
I'm also going to change the short wall with no door to have a double door wide enough for a car trailer, so that I can drive through into the garden (space for trailer). The doors will be wood, and hopefully hanging of a 4x2" wooden frame.
My questions are:
1. Does it sound sensible on the face of it? Not too bothered about what the garage looks like, as it'll be mainly hidden away from view anyway (wall obscured by my neighbours garage)
2. If it sounds sensible, what size steel should I go for? I was thinking something like 50 x 50 x 3 for the main support across the ceiling and also a similar pillar in the middle (resting on plate of steel).
Anyone done anything similar?
My questions are:
