Hi,
I am looking for a bit of advice/experience please.
I have spend a long time looking into the extraction of aluminium dust (lots of DA sanding/grinding). It seems everything needs to be ATEX approvesd, as the airborne dust is explosive - most places say that to do it properly would cost around £10k, even on a small scale.
I have been sanding aluminium ALOT for a long time in a nother workshop with no extraction, and have not exploded yet - but I want to do things properly in my own premises.
Fume extraction is already sorted by an arm and fan.
There are a few methods of extraction:
- on the tool - Festool do an ATEX approved mobile extractor @ £1800
- downdraft / side extraction - cyclone/spun, wet collector, dry filters
Extraction on the tool is a good one, but in theory all tools should be air powered (sparks) - which can be restrictive, and the compressor logistics are complicated. I don't think they would remove enough airborne dust either.
Downdraft tables look great and should tick all the boxes - but they are quite expensive. The airbench ones look fantastic and relatively cheap (approx £2500) compared to the competition, but still too expensive for me.... http://www.airbench.com/en/?gclid=CL-58deAmrwCFUsOwwodMCwA7g
...they are not ATEX approved, but hold the dust on filters so it is not airborne/explosive.
I would prefer to make my own, like the weldingtipsandtricks chap:
This means I can attach the extraction arm to a fabricated table when I need it to draw air down... but then I need an ATEX fan (?) - £1000+++
I have two questions (broken down into many!):
- How can I make a downdraft table with filters like the airbench version (I can send the extracted air outside, but would want to filter it briefly first
Airflow required for a 1x1m table top?
upside down Hood shape, to produce an even draw over the table surface?
Were to mount the filters?
What filters?
Does the air circulating through the table cause a threat of explosion, how can I minimise this?
Do I need to paint it in anti-static paint?
- Do I need an ATEX approved fan?
The fan is mounted outside, so the actual motor would not have dust passing over it, but can the turbine produce static, or risk of sparks?
It would be pretty straight forward to produce a table like the weldingtipsandtricks guy, but there are added complications with aluminium - as above.
What do you reckon? All help is much appreciated
Sam
What filters?
Sam
