Hi Guys. Drilling some 12mm holes in 22mm mild steel pipe. Problems with ejecting the slug from the centre of the annular cutter, some times it does, more often doesn't, right pain.
Thanks guys, All things working, spring I think could be stronger but as Argoshield says it's due to it being pipe. I have 400 plus holes to cut don't think the hole saw would be practical.
The holes are cut at each end of the pipe, the pipe is welded into a barrier, holes are for galvanising process. Time consuming and awkward using pillar drill which I have used previously. Tapping the cutter with a brass drift does sometimes dislodge the slug but will try the pick.
