postie jon
- Aberdeenshire, Scotland
just purchased a rage 2 multi purpose chop saw,any comments ,good or bad much appreaciated.
Gloves and long sleeves, they spray out hot metal chips.
I think they are brilliant but I only use it to cut up pallet bearers. I try to avoid nails but it doesn't matter if I hit a few. Believe it or not hard wood can cause more wear than the nails!
It is VERY noisy so wear ear muffs. The trigger is a pain literally as it won't latch so it hurts after a while.
I did a few test cuts on steel angle and aluminium - it works but a bandsaw would be better. I found with aluminium that chips will almost weld themselves into the teeth and need digging out.
Keep your receipt safe - my first one suddenly started sparking and popping after 9 months light use. Amazon sent me a new one with a new blade!
did you have to return the sparking one?I think they are brilliant but I only use it to cut up pallet bearers. I try to avoid nails but it doesn't matter if I hit a few. Believe it or not hard wood can cause more wear than the nails!
Yes sadly!did you have to return the sparking one?
Ah yes, the £5.99 Erbauer deal. I need to grab a couple of those!Great saws for the money, i buy replacement blades for mine from screwfix, just as good and only £6 each at the mo![]()
The blades are 355mm - couldn't find any that big in screwfix or am I looking at the wrong thing?
