the rage 4 blades have 20 tooth blade speed 3900 where as the fury 16 tooth blade speed 3500 both 185mm.
is it possible to use the fury in a rage 4 chop saw?
why I'm asking well the fury is a little cheaper.
that was a quick reply.
when I used my saw the 1st thing it did was to throw out 3 tooths.
I was cut 12mm x 12mm tubing, what had happened is that the tube spun around.
I notice that the jaws are curved(bending)at the base,there for little grip also the jaws are to smooth to get a decent grip with out using garilla force.
maybe to try a fit a 5mm aluminium sheets to the jaws.
