The 230 VAC Live input to the PCB is on pin A2, Neutral is pin A3. The Live on A2 also goes to the fixed contact ( 2 ) of the relay.
When energised, the moving contact of the relay ( 1 ) feeds the Live out on pin A1, which send power to the main transformer.
The resistance of the primary of this very small low-wattage transformer should be a few hundred Ohms, the 12v secondary a few tens of Ohms. There should be no continuity between the primary and the secondary. The circuit diagram shows only 4 pins - 2 primary, 2 secondary. Maybe the 5th pin is not used, or it could be a centre-tap on the primary for a possible 110v input version.
[ This transformer only runs the relay coil, and the yellow overtemperature LED. The power for the wirefeed motor comes from the rectified output of the main welding transformer.]
These small 12v transformers are available; search for "12v PCB transformer" or "12v encapsulated transformer". For example:
https://www.ebay.co.uk/itm/Transfor...1-5va-230v-AC-125ma-Piece-Housed/192100761297
https://www.ebay.co.uk/itm/Encapsul...hash=item2a1b163b77:m:mpFybSmUGjedKeMwvxSIPeQ
https://www.ebay.co.uk/itm/Encapsul...076606?hash=item1c41167afe:g:rj4AAOxyrrpThbi4
A new transformer may not have exactly the same pin layout and spacing as the original, you would have to adapt it with short extra wires.
