ChrisJohnsSculpture
Does anyone have any experience with the ESAB Aristo Tech 5-13 ?
http://www.migtigarc.co.uk/Welding_Helmets/ESAB_Aristo_Tech__5-13/esab_aristo_tech__5-13.html
I'm using a generic adjustable shade mask at the moment but it struggles a bit with low current TIG and I'd also like something which can be used for plasma cutting.
The published specs for this one seem to tick all the boxes I'm after but it doesn't specifically state how good it is at picking up low amp TIG arcs.
I'm also considering the Speedglass 9100 range which seems to have some good extra features, although the internal controls do look a bit fiddly. I often work on quite big assemblies with variable lighting conditions so the ability to change settings easily on the fly is quite important. Similarly a grinding mode where you have to take the mask off to activate it seems to defeat the object a bit to me...
I've also read mixed reviews of the 9100 build quality, especially the headgear.
I spend a lot of time welding (TIG, MMA and MIG) so I don't mind spending a bit for quality and performance, and I'd rather buy a good tool once than a cheap tool and replace it every few months, although my budget is not unlimited.
Thanks in advance,
Chris.
Thanks in advance,
Chris.
. Not quite sure why you need to switch them on...? other makes, including Esab seem to have got round this one?
