I have an ERP MIG 150 TURBO welder with a wire feed problem...the problem is i think the roller is worn out as even if i crank down the tension there is no grip on the wire...I have removed the torch and liner and just tried the wire thru the feed it turns and so does the roller bearing but does'nt push the wire thru....i have found what looks to be the same type of roller for a Clarke 150 mig and noticed that the grooves for 0.6 & 0.8 wire are actually knurled... should they be like this on my ERP...looked on net for a replacement and cant actually find a replacement for ERP and also on the Sealy welder which i believe is the same. Any one know the answer or where i can obtain a new one....otherwise i am going to bang it in a lathe and take a few thou of it or try and re knurl it, even tho it shoud be case hardened...cheers for any help
