oilcooled :)
Pipe Welder, Mechanical engineer
- Ireland
i was working my chainsaw the other day when it seized. the saw obviously got hot, i was using my friends 50:1 mix, looked in the book and saw recommends 32;1. does the oil help keep it cold as well as lubricated. i let it cool, took out carb sprayed wd40 down port hole took out sparky, poured boiling oil in there, and got it freed up again. saw seems to run as good as ever. my q is why did it heat? cause of the mix, cause its old, cause its all made of cast magnesium which may retain heat in the engine(alu piston metal block) cause the exhaust is half shot? i bought a compression tester today of ebay 9 pound. what would be healthy a reading?
i ordered new rings exhaust carbuerettor conrod. i have a better condition piston and block than whats in it.
old homelite super xl. also petrol boils when worked, told thats a very common problem
engine tester seems cheap and handy
http://cgi.ebay.ie/ws/eBayISAPI.dll?ViewItem&item=330441767122&ssPageName=STRK:MEWNX:IT
