S SCP New Member Messages 8 Jan 26, 2016 #1 Hi is normal 2k car body paint good for engines as it would look a nice finnish sprayed on or will it come off with heat ,or should I use brush on engine enamel an put up with brush marks etc cheer's
brightspark Member Messages 41,681 Location yarm stockton on tees Jan 26, 2016 #3 either 2k or smoothrite enamel sprayed on. use an etch primer 1st
langy langys rodshop Messages 6,087 Location London Feb 4, 2016 #4 2k is fine on heads and blocks, surface needs to be very clean, epoxy primer is the key to a lasting job.
