normspanners
AgreedThe rings must seal to start compressing the fuel/air mixture before its ignited though so I don't see why it wouldn't work? There are lots of other issues to overcome I agree but I don't think the rings sealing is one of them.
The piston rings in most of the pumps I have seen have been exactly like IC engine rings and I have repaired pumps with ic rings that have fitted the compressor pistons, usually used the second ring as it is thicker, when the comp parts where unavailable and as most engines normally max out from 150 up to 200 for a competition engine, I agree also, and dont see the issue, the main difference between compressor and ic are that compressors dont have positive bore lube as engines do, so dont require an oil scraper ring.Take a look at the piston from a compressor pump, and note that the compression ratio is far higher than an IC engine, and that the ring set up is very different.
At the end of the day an engine is a compressor, especially a diesel coz thats how it works.
If an engine pump as is, gives 150 or 10 bar I dont see the need to make it go higher because most compressors stop at 10bar anyway.
And with the volksair, if using equal sized cyl you dont want the compressor to be too efficient anyway because the power side of the engine wont handle powering it.
