NIGEL LANE
New Member
- staffordshire
Hi gents i have just got a load of messer 27 mg690 are these a good rod
Bit of overkill for that.....No you cant oxy acet it........they are very expensive rods you know.....at least £50 / Kg maybe double (ive not been involved for a while)Cheers gents they do make a very nice looking weld and they are free so all good just using them to weld dumper truck A frames to support bars so i can machine the bearing diameter have to use plasma or cutting disc as oxy prop will not work that well when i cut through the welds to remove the support bar
maybe 2 grands worth thereIm not m8 im welding a support bar on the frame so i can mount it on my milling machine then cut it off the bearing diameter that is re machined is done on a mig bore welder will use some 6013s when i pick more up did not realize that they are so expensive got 25kg given to me
