Woody.v8
Blue gluer
- staffs
The version I use has more insulation and is spot on for industrial work.not insulated have to be careful for stray arcs , and look out if your gloves are damp
IdemI like the crocodile spring ones for speed and angle options (without bending) however good ones are getting hard to obtain as more and more folks are raised on these plastic screw clamp types .
Coz you just get the angle in your head . Next to in is the same , unlike a modern type reliant on BendingIdem
I prefer crocodile spring ones for angles options
Yes but I think that a twist lock ,is better when you have to use different sizes of electrodeCoz you just get the angle in your head . Next to in is the same , unlike a modern type reliant on Bending
It is with the rubbish they make now wasn't an issue in the pastYes but I think that a twist lock ,is better when you have to use different sizes of electrode
1,6mm to 6mm as example
But I generally work whit 2,5 and 3,25mm so I use the crocodile spring ones
Yes is it I changed this one's with this other View media item 10170It is with the rubbish they make now wasn't an issue in the past
I have heard nothing but good things about this pricy little guy.Stinger v , not cheap but built to last.
