Not entirely sure where this should be posted.. so I'll appologise now if it's in the wrong place.
Question.. Is there any way of knowing what current (Amps) a welder is pulling down a cable when being used. For the purpose of this question.. use a 250 Amp Oxford as an example, being used at full tilt. (Is there a difference between Arc startup and welding mode?)
Reason for asking.. I want to run a cable from the house through the roofspace via gantry cable to an outbuilding. (approx 30 metre run). I only have a 110 Oxford which I'm 'playing with' at the minute, which works fine on a 13 amp plug, but if I wanted to upgrade to a larger machine in the future, I want to make sure that the wiring is capable of coping with the load.
I would intend having a large(ish) compressor (something wired to a 30 amp dedicated switch) as well as the usual sockets, lights etc.
As I would be working in the place on my own, in theory only one piece of equipment will be used at any time. It's just in case the compressor and welder would be running together, that I need to get the right size of cable worked out so as not to overload the circuit. (Hence the question)
Any advise or thoughts on the matter?
I don't get a chance to get on here very often, so if I don't acknowledge anything straight away I'm sorry, but will reply.
Thanks, Tony
Thanks, Tony
