as ive done tv damage repair before you know and can see heat damage caused by a fires heat
just incase you dont know i will point you to this info
However, as a common standard, older LCD and Plasma TVs have a higher heat resistance of around 120 degrees Fahrenheit before damage occurs. Newer LED and OLED models can start to experience degradation at as low as 90 degrees, more severe damage occurring above 110 degrees.
You might be asking why this is important. Simply put, if the television gets too warm, it can not only destroy the device, it can also release toxic fumes, catch on fire, or explode. All of this can be easily avoided by erring on the side of caution.
after this info its your problem where you fit the tv
