- UK
Have a little conundrum.
I need to form some infill panels from punched sheet. The sheet is pre galv, with the holes punched through after the galvanising process. I need to cut the sheets down, and so to hide the cut edge i was planning to tack a 10 x 3 flat along the edge. Its up a building from ground level to 20M up. Galvanising after fabrication isnt an option as the holes will fill with galv and the sheets will no doubt twist to ******y. They are to be powdercoated.
Even if i spray galv the 10 x 3 strip, i have concerns that rust will start to seep through from it all after a while.
Had the idea of spraying it all with a decent enamel paint instead of powdercoat to give a better level of corrosion protection.
Any thoughts?
Any thoughts?
