Gritineye
I bought a new electric oil cooler fan off eBay, it worked for a bit, then stopped forever the moment I started the engine.
So I messaged seller.
Me
Hi, this fan is rated at 12volts, as it's for automotive use please could let me know the maximum voltage that this fan will run at?
Seller
Hi, glad to help you,Our products are available in voltages from 12v-36v.Regards.
Me
Thanks for that but I think you may have misunderstood my question. With a 12 volt vehicle system the voltage can vary between 11v and 14.8v due to alternator out put. What I want to know is are your 12 volt fans able to work over this range without problems.
Seller
Hi, my dear friendthanks for your message,It can be used within the limits you have described.Thanks for your understanding.Regards.
Me
In that case I think there is a problem. I fitted the fan and it worked ok. Then I started the engine and the fan stopped working immediately, and hasn't worked since. I checked the battery voltage and it was 14.7v. Do you have any idea why that would happen?
Seller
Hi,Glad to help you,We have gone to check with the technician and will get back to you when we have the results.Thanks for your understanding.Regards
Me
Any progress on this problem yet?
Seller
Hi,Glad to help you, sorry to hear that,I'm very sorry, the maximum voltage we can use is within 12v.Are our products not working properly? Or did you find our products ineffective after using them? We can give you some compensation, it’s ok?Looking forward to your reply.Best regards.
Me
That fan was sold as being for automotive use, so it should be able to run at the normal voltage in an automotive electrical system. As you have confirmed to me it can't run at over 12 volts I consider the fan was miss sold to me as it was not as described and unfit for purpose.
Seller
Hi,Thanks for your message,Hope you can understand the return will cause much troubles and need a high postage.To save your time, we can refund you 40% directly you also don’t need to return, can you accept ?Sorry again and hope you can forgive us .Regards.
Me
Can you explain why I would want to pay 60% of the cost for an item that is not fit for purpose, and doesn't work now?
Seller
Hi,Sorry again for this matter, Hope you can understand this is really hard on such period.We only do a small business and also paid a high postage and ebay fee.We can refund you 60% and you don’t need to return anything, it’s ok?If you really don't need it you can resell it second hand or donate it.Thanks for your understanding and we will do better.Your's sincerely.
Me
This is ridiculous, you are suggesting that I commit fraud by selling a faulty item? Refund me my money or I will open a case with Ebay
Seller
Dear BuyerSorry for the inconvenience, I'm very sorry, we didn't mean what you said. For electrical products there may be voltage problems this is normal and did not deceive you. Maybe you can try again to see if it works, if not we can give you a refund.Looking forward to your reply!Best regards.
Me
If it still worked I would never have started this conversation! I'll take the refund, thank you.
Seller
Hi,Thank you so much ! so kind of you !If you have any questions, you can contact me.Best wishes!
Me
When can I expect my refund?
Seller
hi,thanks for your message,I'm very sorry, did you agree to the 60% refund that was previously negotiated for you as compensation?If you agree, we will refund you immediately.Looking forward to your reply!Best regards.
Me
Item faulty and not as described, so I'll accept full a refund only.
Seller
Hi,Sorry again for this matter,we have refunded you, you can check it.Thank you,Best wishes.
Me
Thank you.
eBay
B******: You just got a refund.
Me
Me
Seller
Me
Seller
Me
Seller
Me
Seller
Me
Seller
Me
Seller
Me
Seller
Me
Seller
Me
Seller
Me
Seller
Me
Thank you.
eBay
Me
