Is that still the case if the flex runs through a metal base or tube, though? I'd have thought you'd still need to earth that in case the flex chafed on the casingDepends on how you run the cable.
If for instance you ran flex to a double insulated lamp holder then no.
You'd have to meet specific criteria like insulating glands at every point that the cable enters or exits a tube, any pinch points etc. It's far easier just to earth the metal components of the lamp.Is that still the case if the flex runs through a metal base or tube, though? I'd have thought you'd still need to earth that in case the flex chafed on the casing
(that said, wife just bought a copper lamp that came with an [illegal] European two pin plug...)
correct the flex is double insulated through the metal in to the lampholder so thats not a problem . a lot of bought lamps are the same where the cable enters the fitting it should have a cable clamp fitted so that it cant be pulled out . put a brass lampholder on and only THEN it needs a 3 core flex and be earthedDepends on how you run the cable.
there isnt any risk. class 2 is safer than earthed. if the earth wire gets damaged broken or pulled out from the plug the metalwork can become liveJust earth it, and eliminate the risk.
Got to live a little, gods sake, man !there isnt any risk. class 2 is safer than earthed. if the earth wire gets damaged broken or pulled out from the plug the metalwork can become live![]()
