mart
- South Yorks
An outdoor lamp fitting is constructed of plastic non-conducting material. The manufacturer supplies this lamp fitting with a short length of 2 core (live & neutral) wire inside, connected to the bulb holder on one end, and the usual plastic block connector on the other end. All quite normal.
If for example a 3 core cable is run to this lamp, (whether it is armour, TW&E or the IP rated rubber sheath type), what would you do with the earth at the lamp end?
I heard that an earth that is not connected to anything over time will build up and retain a certain amount of current that one can get a "belt off". Is it officially considered bad practice to use 3 core on something like this? What if the end of the earth was connected to one of the securing screws holding the lamp to the wall for example, instead of leaving it unconnected? Or, is it just better to simply use 2 core cable?
