I am not sure what size Dinze sockets fit on the DIY range of machines but if you have an industrial type machine buy an earth with the biggest dia cable you can.
a decent clamp can be obtained for not much more than a fiver which are a much more powerful clamp.
Sometimes placing the Earth clamp has an effect if you are welding into corners, especially on MMA. Because of a thing called Arc blow, its basically a build up of magnetism and causes the arc to become erratic and unstable. The earth clamp can be moved onto the direction of travel and sometimes this helps.
