skotl
- Edinburgh, UK
I'm in the final stages of building my trolley and tomorrow's plan is to mount a 32A socket on it for the welder, as well as a 4 gang that I can plug the plasma and grinders into.
There will be a cable coming into a 32A isolator switch, through to a junction box that will feed the 32A and 13A sockets.
It occurred to me that I should run an earth from the junction box to the trolley's chassis as it's sitting on rubber wheels so is mostly isolated. I say mostly because earth leads from the welder and plasma will contact other grounded items, plus it will inevitably come into contact with other grounded items.
But then a bit of me wonders whether it is more dangerous to have the trolley presented as a route-to-ground if any of the kit develops a fault.
Thoughts?
Edit: The garage is RCD protected, if that makes a difference
Thoughts?
Love it! Yes you could make it all class 2 with plastic accessories and that would also be perfectly acceptable
yes that would work but be Careful with the fixings for the boxes as they are metal, and coming from inside the electrical enclosure. Fixings on class 2 installation are usually seperated from the enclosure by insulation and caps in the face to hide cover screws.
