I am in the process of making another Alternator welder, this time using 2 x 160A Prestolite truck alternators, 2 external 3Ph rectifiers & an 18HP Honda GX610. Electronic control of fileld coils.
The rectifier DC outputs will be in parallel to obtain the required weld current.
I need 2 alternators because each alternator is rated at 150A / 14V (2240VA), so at say 35V/160A would require 5250VA, & I am after high duty cycle use.
No issues with stick as I can trim one of the field currents to achieve reasonable current share between the 2 alternators.
However I also want to use this as a MIG power supply & I anticipate some difficulty with current sharing between the 2 alternators with voltage regulated output. Untill I test it though, it may be easy to achieve.
I would be interested if anyone else has tried this before & any details on technique to obtaining reasonable current share with dual parallel alternators in voltage regulated mode.
Thanks
Thanks
