bigegg
- Leeds, West Yorkshire
In my neverending quest to build a laundry room/covered wahing line/ "conservatory"
I have reached the point where i want to dryline the walls with insulated plasterboard.
The conservatory is roughly octagonal with each section 4ft in length, and 2ft high.
The walls are single skin brick, no dampcourse, and painted (internally) with a couple of coats of toolstation's finest bitumen paint.
I have some sheets of insulated plasterboard i pulled from a skip (approx 40mm of kingspan type foam, 12mm of plasterboard)
Should i space the board off the wall with a 2" tanalised wooden frame?
If so, should the timber run vertically? Horizontally? In a grid?
Adhesives?
Im thinking pinkgrip/construction adhesive to fasten to the brickwork, then screw the plasterboard to the timber.
Or... the same stuff to dot and dab straight to the wall?
Eventually, im intending to woodpanel the walls over the plasterboard - i'm using it because it's here, it was free, and i want *some* insulation.
Additional info:
Its very well sheltered (no driving rain) and well above (12") ground level.
The floor is dampproofed, and the bitumen paint tanks the floor as well (under the polystyrene insulated screeded floor)
Adhesives?
Additional info:
