Hi, i need to re position a couple of holes in an engine bracket , basically i need to plug the original holes and re drill slightly higher, the new holes will overlap the plugged holes slightly, my Q is will it be a pig to drill the welded area ?
Its a good question and the trick is to weld it at relatively low power but keep spotting it in so that when the hole is filled it’s nicely glowing and takes a considerable amount of time to cool.Hi, i need to re position a couple of holes in an engine bracket , basically i need to plug the original holes and re drill slightly higher, the new holes will overlap the plugged holes slightly, my Q is will it be a pig to drill the welded area ?
