Allthegearnoidea
- Sheffield
Does anyone know if its possible to drill and tap railway rail such as flat bottom 113A or bullhead. I know that its possible to drill with a rotabroach cutter as I do this routinely.
I would normally drill through the entire rail and bolt through the holes and clamp using fish plates. However for this application it will be a blind hole as I can only get access to one side of the rail and I cannot bolt through. The other side of the rail is cast in concrete.
I want to drill the rail through the neutral axis and then tap the rail to accept bolts. This is not a main line standard job. Im trying to install some lift up stops to stop bogies rolling away.
I am not sure how hard rail is and if it can be tapped etc.
Chris
Chris
