My preferred method where possible is to cut a slot across the stud with a 1mm disc or hacksaw and get some heat into the tapped bit and then wind the broken stud out with a screwdriver.
Hot droplets of metal down my sleeve would probable feature in my future were I to try and weld it.
duct taping your sleeves at the wrist can helpThanks for the advice. The stud broke as I tried to remove it with a stud extractor, there is limited access, it is an XJS vee twelve.
I can use the extra holes Jaguar tapped in the manifold and rotate the locking collars. Then the brackets for the heat shield will be in the wrong place.
I will try drilling in preference to welding, when I tried a drill on a piece of the broken stud it seemed unwilling to cooperate.
Hence the question, I was hoping for a magic drill bit.
With better access I would probably try welding. As it stands I will have to introduce the drill from above and then reach up and operate it from under the car.
If this fails I will have to make new brackets, just trying to keep it standard.
Regards Kels.
I wish i had your luck mate![]()
