Hi have been welding my van up today then the welder just stopped its just clicking no wire coming out has been working great before this any one got any ideas it's a draper 180 t
Unplug welder from mains Then make a note of which way round the wire feed motor wires go (as the have to go back on same way round) Now using a battery charger as a 12 v supply connect to wire feed motor and breifly switch on charger to check that the feed motor is still ok. If motor turns then motor is ok! and it could be the supply to the motor which will come from the controller pcb. Check to see if there are any fuses on this board? Post up a good pic of pcb, might be able to guide you as to what to check.
