best drain the lot off if u can and the radiators. the heating pipes will freeze as well if not in use/ frost will expand and split the pipes and blow the jointsis it best to drain cold water and hot water tanks in this weather if not using them for a while?
turn off at the mains and open hot and cold taps ?
is that enough?
guess the radiators are ok ?
if its a vented system with a header tank cut the water supply 2 it and drain some water out of the system. buy some fernox and tip it into the header tank and refill . turn system on and run throughwhat is best inhibitor to use?
how do you put it in the system?
