Was down at the local scrappy's this aft and he has about 6 sheets of 5mm x 120 cm x 150cm (approx. 4x5ft) laying around. Wants 36 euros per sheet. The sheets are unused with just some light rust.
Now I need to make a welding table but I'm worried that 5mm is just to thin. Is it plausible to double up on the sheets - ie 10mm thickness - by boring say 3/4 inch holes through the top sheet and welding it to the bottom one? Will the finished 10mm thickness be flat or will it be distorted all over the place by the heat? Has anyone ever done this?
