Shiny Steve
- kent
Hello people, as the title does anyone use AirPods in the workshop are there any issues.
An advantage I could see in the workshop is other folk will know you’re wearing them -
Exactly the same scenario - unless the plant has upgrade to ear defenders with intercoms - although the first time I was given then was 20 yrs ago and the only place they worked was in reception . . where it wasn't exactly noisy.In the ball bearing plant I worked in, ear protection was a compulsory thing.
Only real problem was that when anyone needed to talk to anyone else they had to get right up next to you and shout in your lug'ole.
No wonder I called it Halitosis Hall.
What potential issues are you envisaging? Earphones are no issue as long as you stay aware of what you're doing. Same as at any other point in time.
I found grinding fine with headphones and woolly hat (was outside) though I use Samsung buds so they're in ear rather than airpods just hooking on your ear unless they're changed since that design.I’m curious as to whether they will suffer from the environment. I do a lot of late shifts where I set aside welding projects for when the maintenance jobs run quiet. (Lots of tiging baskets for production wash machines and heat treat)
As well as how do they affect your hearing whilst grinding and as like
