Hi,
We've just had solar panels installed on the barn roof, running through a 6kW "Solaredge" inverter to a dedicated circuit from the garage DB.
My question is whether I should shutdown and isolate the system when I'm going to be using a welder. Both my stick welder and the MIG are inverter sets running from 13A socket.
As a cautionary tale from my youth, the outfit I worked for used to service and repair Solartron flow computers. We had one in from a distillery that had died, reportedly after an arc welder hd been run off the same circuit. We ended up replacing just about every IC as ech time we sent it out fixed, something else would fail a week or so later.
