Ventilator
New Member
I need scheme plazma cutters with electronics or some older production,I need that it can that cuts the thickness steel up to 10mm
What are you on about FranV8?!
Loads of people build their own plasma cnc, there is no more risk than using one manually, probably less since you aren't actually touching any of it while it runs.
What an odd reply.
There is more info on CNCzone.com than you'll ever need, including a set of full plans to build you own.
If you stop at any point to eat lunch while building your CNC plasma, please note that you use a knife and fork at your own risk.
Al
