I don't really know why folk use etch primer on 'glass, though it seems it is used, the acid is surely pointless on anything except metal? I've used epoxy before, it's a proper sealer and used on boats; but is 2k.
You can etch your ally panels, may as well use etch on the 'glass I guess.
Buying paint is no prob, either over the net, or at a local shop. Advantage of a local shop is leafing through books of chips. Or if you have a factory colour in mind they might well be able to suss a code/mix it. Also if you have a code to hand you can get it mixed and posted.
worked a treat
