As mentioned we have a TD5, it is the only car that I have hated, I seized the engine a short while ago, we did try to bump start the car using a Land Rover 110, just to see how seized it was, when I dropped the clutch the 110 stopped, it is knackered.
Replacement TD5 engine has just been fitted, what a difference, you have acceleration it actually pulls with power, always thought the old engine was cr*p but now realise how bad.
Believe on the replacement a small hose might be torn so will replace that and that will cure the slight flat spot, which even with is still far better than the old one.
Why did it seize we have always had a water/coolant leak, needed filling every couple of weeks could never find the leak and when a hose did go jump for joy as believed that was the issue ( small pipe below the turbo about 3inches long with different diameters at each end!
But no it still leaked, new radiator etc still leaked, why did the engine stop we believed it hydraulic'ed.
Speaking to someone else the TD5 does have some issues and this is one of them
