my p reg central locking has gone bonkers ,should be able to reset buy rekeying number in from driver door but now found that it must be a replacement door and unable to to do that as key does not fit any thoughts on this
If your taking it apart id change all the door lock springs as there gonna go next, only a few quid and a couple of minutes work
That's what I was thinking.
I've had mine for four years and so far (gets stick ready to prod fate) the only door issue I've had is the drivers door which seems to commonly be a spring issue as above, but lots of silicone lubricant sprayed dwon the locking tab at the door sorts it out. Was just thinking that if the originator clarifies what he means then checking the easy things first would be best rather than jumping in with fobs and barrells first
