Guineafowl
- Nairn
Digital Phase Converter 4Kw/5.5Hp 240V in 400V Out - JFK Electrical
4 Kw / 5.5 Hp 240 Volt Digital Phase Converter Input Volts 240 Single Phase ( Supply 32Amp type C Mcb ) Output Volts 415 Volt 3 Phase ( No Neutral ) Dimensions L 280mm x W 145mm x d 180mm Weight 4.5 Kg Change your Garage/Workshop from single 240 volt to 3 phase 415 … Continue reading Digital...
Looking for 3 ph in the workshop, and this ^^ comes recommended. Looked at rotaries, but they seem noisy and expensive.
Current machines to run:
1. 1.5kW planer, normal DOL start.
2. 2.2kW radial arm saw, DOL start and DC brake.
3. 2.2 and 3kW spindle moulder (+small power feed) DOL start, but two-speed Dahlander motor.
The JFK electrical chap rang me to ask what is to be powered, and says the DPC won’t run a DC brake without a (very expensive) sine wave filter, but I can’t see why not. Any ideas?
I already have some VFDs, but I’ve ruled them out for these machines because:
1. It’s one per machine and I’ll probably get more 3ph stuff in the future.
2. They don’t like DC brakes, and braking resistors are pricey.
3. Hard to set up for a Dahlander motor.
