chrismac
- Highlands
What is the thoughts on using CT 1 or Dow 799 for holding the glass to the metal runners which hold the glass in place by the adhesive only no mechanical fixings.
Had a bit of a disaster, well I never but the guy who unloaded the machine has put the lower window in bits and thankfully the top section which must have been repaired in a fashion fell apart and the glass stayed intact, I am going to use some polycarbonate to replace the small lower section, just looking into getting the top window reassembled, I was planning hole punching some thin rubber gasket as a spacers so there is a couple of mm of bond allowing for flex, is this a good idea or not, the spacers would be set in the flexible adhesive.
