DAPPH
as dyslexik as I'm daft
The dishwasher was a 9 yr old top of the range Bosch , it died yesterday morning " Yipeee " .
I now have access to six areas of thin gauge high quality stainless steel ... so I thought .
After getting the new replacement TOR Bosh in & set up I decided to take the old one apart to get some thin mild steel sheets , some reasonably precision fabricated angles etc. ( the door hinge bits ) some quality thin stainless steel sheets where I can get several flat squares of about 170 x 170 mm with a bit of careful cutting.
What I didn't count on was that all the external surfaces of the stainless " cupboard " have been given an adhesive fixed 7 mm thick coat of some black hard tar type substance which is part of the heat insulation and sound damping designs .
Have any of you guys done similar , if so how did you remove the black gunge off the stainless steel ?
