Seano
- Devon
How's the tool holding up?
I'm swithering between this one and the Bosch GSC 2.8, which cuts thicker sheet. Comparing the specs, the 2.8 seems better. Does the GSC 10.8V-Li have any advantages over the 2.8 (other than being battery operated)? Does the 10.8V-Li cut a smaller radius curves?
If anyone has any other recommendations for a good quality power shear that can produce detailed work, i'm all ears. It's for sculptural work, I currently have access to a plasma, but would like a quieter, neighbour friendlier option.
Have also been looking at the same model after a lot of deliberation between plasma cutter, vertical band saw, the only other choice is what I term as scissor type shears, which use the two finger, centre cutting finger setup, my main criteria is size of min radius, the GSC 2.8 is 25mm I believe which would be the stumbling block for me, nibblers would give me this, but the cutting waste from them is a nightmare.
dropping over would be a good idea if I was closer...but the I have my left leg in a pot anyway until September (not conducive to very legal driving).......
