interesting, how did that work out?I do use multitools ( mains and 12v and 18v cordless ) but I find that the blades are coarse and they do not last long on steel. I have experimented with welding segments of 32 TPI hacksaw blade onto worn multitool blades.
Not good, the segments cracked and fell off. Next time I will use bi-metal hacksaw blades, cut down to just the toothed part, then brazed to the worn multitool "carrier" blade, and the joint ground smooth.interesting, how did that work out?
aye, I did wonder about the heat affecting the tempering of the blade. Maybe brazing or silver soldering would be more controllable. Anyway another "job" to add to the list... next time I've got set up for brazing I'll give it a go, there's a few tired ones in the box so, have some to try on... will report back when I get time.Not good, the segments cracked and fell off. Next time I will use bi-metal hacksaw blades, cut down to just the toothed part, then brazed to the worn multitool "carrier" blade, and the joint ground smooth.
My mains-powered one is a Fein Multimaster, but the original HSS blade is worn and I use cheapo Lidl blades.do you use the proper blades?
