I need to cut 12mm dia nylon bar into pieces approx. 18mm long. I say "approximately" because I can't remember the exact measurement off the top of my head but the length actually needs to be precise.
At the moment I am doing this on the bandsaw but that leaves a rough cut and a lot of swarf to clean up. I've tried using a hand-held MDPE pipe cutter and this would cut cleanly two-thirds of the way before the piece snapped off so it looks promising but not quite there.
I would appreciate any suggestions for doing this cheaply and fairly quickly (I cut quite a few for each batch) but also cleanly. The bandsaw is fast but the cleanup takes time. I wondered about something using heat but I don't want to invest too much in tooling as it would take quite a while to recoup the cost.
