Beanmetalworks Member Messages 237 May 28, 2013 #1 Hi whats best way to cut squares out of the side of a galv sheet????, for example cutting square for latch hole on a sheeted door. thanks
Hitch Moderator Staff member Messages 13,498 Location England May 28, 2013 #2 If its awkward, plasma does okay. If its a large notch, careful use of a disc can do the trick, finish off te corners with a file for neatness.
madkayaker Pro sparkey Pro Welder Messages 13,655 May 28, 2013 #3 At work we have a punch for doing nice square corners just like that can take photo tommorow
N nickk Forum Supporter Messages 5,913 Location Hay-on-wye May 28, 2013 #4 punches ,nibblers,even a saw/chisel. Just try & avoid anything with heat especially grinders as they burn the zinc & cause future rust spots.
