As above, I think my Rage 3 (255mm blade) would do it in one cut, I was cutting 300mm wood for book shelves yesterday, I can't remember which saw Scott has.i would clamp it tight and use ur rage saw then turn it 180 deg and cut from the other end
What is the purpose of the lolly stick? It looks like a machined face so not for taking up irregularitiessince you have a milling machine...... how about a slitting saw like this
not sure if you will have enough travel of the milling machine though.
Yer, a 355mm should do it in one, get it well clamped down and go for it.Hmmm... might try the rage - it's a 355mm slider so probably could do it in two passes.
Cheers guys!
Tomorrow is a rage/lathe/plasma/mill day![]()
what ya making Skot? 1 pass moght do it but i reakon 2 at that depth
Yup - if I had a bandsaw (darn - next purchase!) then I'd have used that.Bandsaw would be first choice then circular saw
Oh, yes, absolutely! But the stars have aligned where; the family are away for the weekend, I have a new mill, I've got a random block of alu, and I have more ideas than skillGoing against the grain of playing with toys but is it not easier to acquire a bit of metal roughly the correct dimensions to start with
Just a small point, I was taught that only cloth comes in cm, or furniture from Argos!I've got a block of aluminium around 30cm long and 5cm deep that I want to cut down its length.
A brief google suggests that a jigsaw with a wood blade, and plenty WD40, is the way to go - any other suggestions?
Oh no - I'm still clueless when watching American youtube videos when people talk about "going from 3/8th of an inch to 1/4, taking off 17 thousandths at a time". Why would you not want to work in a unit that is divisible by ten?Just a small point, I was taught that only cloth comes in cm, or furniture from Argos!
