Memmeddu
- Italia Sardegna
I can't understand yetits the spark to get the cutter cutting at the gun torch end
Why you need a spark inside the machine?
They say arc start device but the spark is on the torch not into the machine
You were right. Earth wire was corrodedif you are having spark troubles are you having any other sort of issues that are showing up
like torch bits burning out or the electrodes internal arcing
I’m having a problem with my plasma cutter. When I start it up, everything seems fine — I can adjust the amperage, the air pressure is good, and the solenoid valve is working properly. But as soon as I press the trigger, the machine shows an overheating warning, the QC button lights up, and there’s no spark.
I know these are cheap Chinese machines and that most people say it’s better to just throw them away, but I really want to fix it.
Can you help me?
