Sometimes (probably 20% of the time) my tacks will crack across their full length - can anyone advise why this occurs? The frustrating thing is once its done it its actually quite hard to re-do without the same thing happening.
As I understand cracking is usually down to not enough filler being applied? It wouldnt matter if I could just go over it with another run but as I say it seems to repeatedly do it once its happened once!
My actual weld runs are fine (on the odd occasion there might be a small crack at the start of the run but as I'm welding tubes I ensure I cover this as I finish the run.
The materials being welded are 45mm OD tube with a 3mm wall thickness fillet welded to a 10mm thick flange plate.
