grim_d
Unlikeable idiot.
- Scotland - Ayrshire
Hi all,
I finally got the last piece of the puzzle yesterday (gas) so today I had a good go at trying my hand at welding.
My first question is about gas, I went for the hobby option of a 10L cylinder filled to 137bar, confirmed by my regulator, by the end of today, about 7 hours with pretty regular welding it was down to around 75 bar, this seems excessive to me, is it? Flow was set to 10L/m.
Second question is about suitable wire thickness, I started out by using what was left of the 0.8mm wire that was in the machine, this penetrated 2mm and 3mm steel no problem as you would expect.
When I moved onto the 0.6 wire I struggled to get full penetration on 2mm sheet with a butt weld, turning power and wire speed up to almost max helped but not much, is this bad technique or is 2mm pushing it a little with 0.6mm wire? (The power and wire speed calculator suggest I can do 2mm with 0.6 at way less than was possible)
Machine is question is a Cebora stag 186 - 28-185amps.
By the end of the day I had produced this... A tool bogey, my shed mate had been wanting a small cart to put tools and bits on when working on the car, so I made one, not perfect but I am more than happy with it.
3mm box section with 2mm plate underneath, should be fairly strong.
