T Toff New Member Messages 11 Location Linlithgow Aug 17, 2017 #1 Playing about so thought ad show the mess. IMG_0001.JPG 262.7 KB · Views: 47 IMG_0002.JPG 305.9 KB · Views: 50 IMG_0004.JPG 215.2 KB · Views: 52 IMG_0005.JPG 280.3 KB · Views: 57
G gt6s pre-moderated Messages 979 Location Newtownards Co Down Northern Ireland Aug 17, 2017 #2 Seen worse. Decent start. Keep practicing. Laurence
T Toff New Member Messages 11 Location Linlithgow Aug 17, 2017 #3 Still playing about with the settings. All feed back welcome
S Stingray Member Messages 483 Location Northern Ireland Aug 17, 2017 #4 Grind off all the galvanising before you start, the fumes are deadly, with GMAW clean all rust, millscale, galv, paint off before you start also grind where your earth goes on as well..
R Rob85 Member Messages 154 Location Northern Ireland Aug 17, 2017 #5 Seen a lot worse going thru the MOT, bit more fine tuning and practice and that will come on rightly
T Toff New Member Messages 11 Location Linlithgow Aug 18, 2017 #6 The welder came with hobby weld 15 will this make a difference as am being told hobby weld 5 would be better
Jlg Member Messages 2,586 Location Cumbria Aug 19, 2017 #7 @Toff If it is only thin stuff your welding you will be better of with hobby weld 5 because 15 is made for thicke metal
T Toff New Member Messages 11 Location Linlithgow Aug 19, 2017 #8 Jlg said: @Toff If it is only thin stuff your welding you will be better of with hobby weld 5 because 15 is made for thicke metal Click to expand... Yes it will be body panels so I'll keep practicing with this till a get some 5.
