mike os
just a little insane.....
- North Wales
first, joint preperation:- when veeing a joint is there any guidance on what proportion of the original edge should be left? or is is a case of anything is OK, or thin enough that your welder can easilly achieve full root penetration? ( my usual & the obvious choice)
Second:- abrasive cuting disks. Can they "glaze" or somehow loose their "edge", having a great deal of difficulty cutting some reclaimed chanel, seems to cut for a bit then stop & just get very hot with no further progress.... whats happenin dudes? Yes they are metal disks and they are not cheepo's and I used 2 different makes with same result....
cuts OK on the bandsaw though... just seems very strange unless it is a harder grade of steel?
very confused....
very confused....
